- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8500 OpenVPN 3.4.0 not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8500 OpenVPN 3.4.0 not working
Before fixing or changing anything, figure what might cause this error.
FMI List of supported/unsupported config directives for clients with OpenVPN core version 3.8 +
- Mark as New
- Bookmark
- Subscribe
- Permalink
In the ovpn file is the following
sndbuf 393216
rcvbuf 393216
push “sndbuf 393216”
push “rcvbuf 393216”
- Mark as New
- Bookmark
- Subscribe
- Permalink
Comment the push lines in the config file for the moment.
OpenVPN does as a quick fix the availability of older versions to install.
OpenVPN Connect app: "Connection Failed. Unknown/unsupported options present in configuration."
Either way, Netgear seems to have has some massive backlog updating the OpenVPN implementation on virtually all routers supporting OpenVPN, including the generated (suggested) config blocks on all devices following the OVPN 3.4 ff. requirements. @DarrenM (all Nighthawk), @DavidGo (all Orbi), and probably even @BH-C ref. the new RS700 ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I removed the push lines and then I get TLS version too low error.
I can’t load an older version of the client as this is on an iPhone.
‘Thanks for your help but it looks like I need to wait and see if Netgear ever updates the firmware on an R8500 to fix this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Information about what NG products have reached End of Service life:
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is too bad because I have been real happy with this router and it still meets my needs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try using the routers DMZ for any VPN configurations that might help avoid any router involvement as a last resort kind of check.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does anyone know if the RAXE300/AXE7800 firmware supports iOS OpenVPN 3.4.0 client?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might post about that here in this forum:
Check here as well:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OpenVPN 3.4.1 addresses the unsupported option issue.
