- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RESET ??
- Mark as New
- Bookmark
- Subscribe
- Permalink
RESET ??
What is best route to reset a FORGOTTEN password - user name
AND
Security questions for NETGEAR ROUTER. ??
I feel my NETGEAR router has
PLEASE REPLY
paul.boudin@yahoo,com
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RESET ??
You could simply try pushing and holding the reset button for 7-15 seconds while its powered on.
then you'll be able to reinstall it.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RESET ??
I know it was a silly question.
I may call another authority and inquire :
We have a BnB within our home and want guest totally separate from the wife and I private setup.
( SEPARATE PW's )
Plus
I have WYZE security and the cams only run on 2.4 gig
But
We want to surf and use the 5 gig for our needs.
Would you have a very brief suggestion ??
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RESET ??
Without knowing what your device is, its tough to recommend if you need a different router or use the guest network on your current one.
IF your router supports it, you could use the guest network for the bnb guests.
If it doesn't have one, an investment in buying a business class router that supports separate ssid/vlans might be worth it. Then you could have separate networks
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
