- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Paid for Speed Increase, Not seeing it
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am paying for 500mbps. With my provider router I am getting all of that speed and more, but I was sick and tired of paying $7 a month to use their router. And so a friend recommended the Nighthawk. In the past I have used Netgear routers and had absolutely no problem with them, but this one is sad to say a complete and utter piece of garbage.
When I am connected hardwire from my modem to my computer I get 530mbps. When I am hardwired from the provider router to my computer I get 510mbps. When I am connected to the Netgear router I get slightly less than 350mbps, and if connected to wifi I get maybe 250mbps. If I connect to wifi using the provider router I get about 490-500mbps.
How can this be ? Did I get a defective Netgear router ? I did the firmware upgrade as soon as it was hooked up so I know that is not the issue. Do I need to use a CAT6 or CAT8 cable from the modem to the router, and then from the router to my computer ? Is it that this router can not handle more than 400mbps ?
Enquiring minds wanna know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Thabilldozer wrote:I am paying for 500mbps. With my provider router I am getting all of that speed and more, but I was sick and tired of paying $7 a month to use their router. And so a friend recommended the Nighthawk. In the past I have used Netgear routers and had absolutely no problem with them, but this one is sad to say a complete and utter piece of garbage.
In real life, your new router should handle throughput in the 930-950 Mbps range via an Ethernet connection. Wi-Fi has a lot of variables that are mostly dependent on the capacity of the client hardware. For reading at a later date, here is a good reference: https://www.wiisfi.com/
Recommend you use the Ookla stand alone application for testing throughput. It is available at no cost from the application store.
What is the brand name and model number of the modem that is connected upstream between your router and the internet? Please look on the label.
When you replace a major component of a local network, a proper startup sequence is important to allow the devices to adjust communication protocols. Sequence and timing are equally important.
Pull the power cord on your modem and disconnect the Ethernet cord.
Pull the power cord on your router and disconnect the Ethernet cord.
Plug in the cord to power up the modem and give it ample time (a few minutes) to boot and connect to your internet service provider (ISP). One of the last indicators to illuminate will be the one that shows internet connection.
Connect your Ethernet cord from the output of the modem to the WAN input on your router.
Plug in the cord and push the on button to power up the router and give it ample time (a few minutes) to boot and connect to the internet. One of the last indicators to illuminate will be the one that shows internet connection.
Did the internet indicator on your router light up as white? If yes, check for stable internet access from devices connected to your router via Wi-Fi or Ethernet cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I know how to properly setup a network. I know that the modem needs to completely connect before attaching and connecting the router.
This is not the issue. Again, plugged hardwired from my modem to my computer I'm getting over 500mbps. But, as soon as the Netgear router is connected hardwired it drops to 350mbps. This again is hardwired and not wifi. When using the router provided by my ISP (Spectrum) hardwired from their router to try my computer I'm getting 490-510mbps.
This is definitely an issue with the Netgear router. I have troubleshot the dog snot out of this. I've even gone so far as to make sure that I'm using all brand new CAT6 cables.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Measured how?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Uhm, I assume that was a retorical question. How do you measure the speed of your internet connection ? Most, if not all people that want to TEST the SPEED of their internet connection use what is called... wait for it... wait for it... wait for it... a SPEED TEST.
There are several out there to use. I get speeds from at least 3 of them before drawing any definitive conclusions. As for connecting via wifi it is ridiculous just how much speed I lose. For example If I turn off wifi on my cell phone and just use cellular data I get 248mbps down/28mbps up. If I turn off cellular data and turn wifi on, and connect to the 2ghz band on my Netgear router I get 216dn/11up. If I change to the 5ghz band it drops to 180/11. Sure, there will always be a drop in speed connecting via wifi, but it should not be more than half your subscribed speed.
But, again I am NOT talking about wifi. Yes, it is a wifi router, but that is only half of it's functionality. The other half is the ability to plug hardwire into the router. A hardwire connection should not be losing ANY speed. When using the router provided by Spectrum I lose absolutely NO speed when hardwired into their router. So why is it that I am losing half of my speed hardwired into the Netgear ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may think that you know everything about this, but, as I suspected, you are using less than optimal speed tests. You are measuring the speed of devices connected to the router, not the speed of the router itself. You might do better to start with testing the speed between the router and the Internet.
You don't sound like someone who is willing to learn – claims of years of computing experience are always warning signs – but as well as the suggestions from @Kitsap I should throw in another option. That is to use the Netgear Nighthawk App.
The reason for using the app is that it makes a direct measurement between the router and the modem.
It may start with a wifi connection to the router, but after that it is down to the router to report the speed that it sees for its connection to the Internet.
If you see slower speeds with devices connected to the Netgear router, my first move would be to check the devices themselves.
Then there are all the points made by @Kitsap. Did you go anywhere near the desktop speedtest?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to understand where the disconnect in communication is. I have said several times that this has NOTHING to do with WIFI. Let me repeat that and hopefully you will begin to understand. This has NOTHING to do with WIFI. I hope that clears up any confusion that you may be experiencing.
I am HARDWIRED from my computer into the router.
When HARDWIRED into my Spectrum router I lose absolutely NO speed. When HARDWIRED into my Spectrum modem I lose absolutely NO speed. When HARDWIRED into the Netgear router I lose at least half of my speed. This is NOT an issue with my modem. This is NOT and issue with my computer. This IS an issue with being HARDWIRED into the Netgear router.
How does an app on a cellphone tell me anything about the HARDWIRE connection ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you read what I wrote?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I read what you posted. The app only tells me my connection speeds on WIFI. I am NOT talking about WIFI. What part of that are you not understanding so that I can possibly break it down further ? AND, the speed test using the Nighthawk app says 370mbps down and 11mbps up. This is NOT what I am paying for. I am paying for 500mbps/20mbps (Spectrum does not have asynchronous connections). SNR is -43db. signal 100%.
There is nothing in the Nighthawk app that allows for me to test the connection beteen the router and the modem exclusively. It tests the connection to the internet via wifi.
BUT I AM NOT CONNECTING VIA WIFI. I AM CONNECTING HARDWIRED TO A DESKTOP COMPUTER. I hope that helps you understand a little better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just curious if you don't mind, What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
You mentioned that connecting your wired PC to the ISP router gets you to spec speeds. If there is a router here, have you used the ISP routers DMZ or IP-pass thru feature for the R series router while it's in router mode then speed tested? Would be a double NAT condition here that could cause this speed difference.
When speed testing, instead of using the NH app to check speeds, try Ooklas installable speed test app on the wired PC to test speeds here.
Also another test to try, if you have ISP router, configured the R series router for AP mode and test if you get time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Spectrum uses modems manufactured by Motorola. Mine is the E31N2V1 which is rated for 1.9gbps. My Spectrum router (also manufactured by Motorola) is a wifi 6 router rated for 2.5gbps. My work computer MUST be hardwired. My goal in getting the Netgear router is to save the $7 per month that Spectrum now charges their customers for using their router. But this is becoming more of an hassle in an attempt to save $7. The plan was to return the Spectrum router to them.
Spectrum routers do not have an admin gateway where users can configure their settings other than change the SSDI and password. Bottom line is that I am not getting the speeds I pay for using the Netgear router. I get my subscribed speed and more using the Spectrum router.
Since this is a work computer I can not install anything on it without IT permissions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your perception of the router's internal throughput test is wrong. The test measures the input to the router from the modem. The test is initiated from within the mobile application that is connected to the router over Wi-Fi and the results are reported out the same way. This test does not measure Wi-Fi throughput. Historically this test has provided a very stable reference and record of the results.
Within the configuration of your router, do you have IPv6 enabled? If not, it should be.
Are you using the DNS from your ISP? For both IPv4 and IPv6?
Do you have any of the boutique router features enabled like QoS, traffic meter, Armor, etc.?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the modem model is a Hitron:
https://us.hitrontech.com/products/service-providers/e31n2v1-cable-modem-router/
Just curious as we check to see if there is any router built in here, this one doesn't.
Only thing I would do is power off the modem, Factory reset the R series router, Power ON the modem. Walk thru the setup wizard with a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Don't setup any additional features like Access Controls, Armor, SPC, IPv6 or Traffic Meter. With limited default settings and using Ooklas installable speed test app on the wired PC, you should see same speeds at when your directly connected to the ISP modem. Try different speed server with in the Ooklas speed test app as some services may be busier or not as accurate as others that maybe near you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I feel as if I am repeating myself more than is necessary. I can NOT install apps of any kind on the wired PC because it is a work computer. This would require an escalation ticket to the company IT department that I can assure you will be denied.
But, since you guys want to focus on wifi let's do that. I have a 2023 Moto 5G Stylus running Andriod 13 with the latest updates for it. On cellular data only I am getting 275mbps down and 28mbps up. BUT, when I connect to the 2.4ghz band on the Netgear router I am getting slightly less than that. When I connect to the 5ghz I get 180mbps down.
There should not be that dramatic of a decrease in speed over wifi. My wifi connection should at the very least be better than my cellular data connection. But it is not.
I have unplugged the Netgear router and put back the Spectrum router. It's never a good thing when a piece of crap ISP router is better than a Netgear router. I will just have to live with paying the $7 per month.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You don't have a personal home PC to test with?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for that explanation. That's what I was trying to say.
The good thing about that approach is that it eliminates anything that the devices wired to the router may introduce.
Like I said, it can be difficult persuading "experts" to rethink their understanding.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No it doesn't.
It uses wifi to instigate a hardware to hardware test.
But you have been told that several times now, so there isn't much point in trying to correct your misunderstanding.
User | Count |
4 | |
3 | |
1 | |
1 | |
1 |
