Orbi WiFi 7 RBE973
Reply
Red WiFi light after resetting
Capellam44
Yesterday we had to do a factory reset on the router because the password that you wrote down wasn’t working. When the router came back online, we have a red light for Wi-Fi. I can access the admin section through a computer. I have tried different things, but nothing will reset that red light. I also downloaded the Nighthawk app. It did some kind of configuration this morning, but still no Internet. Can somebody help me get this set up?
Message 1 of 11
Re: Red WiFi light after resetting
What router is this?
What do the other LEDs show? Power LED? Internet LED?
Why did you have to do a factory reset?
Message 2 of 11
Capellam44
Sorry, I filled in all the text blocks and apparently it doesn’t show on the post itself. It’s a Netgear nighthawk R 7000 router. The red Wi-Fi light is the one that appears. All the rest are blue. Blue means that they function normally and red means that there is an issue. We had to do a factory reset because we needed to get into the admin section through the Internet. And the username and password that was written down did not work. I was told the only thing I could do to reset the password was to do a factory reset. I know we did this once before in the past and it was not this difficult. When I plug the Computer into the ISP cable and bypass the router altogether I have an Internet connection. So there is something with the router or the settings that I am missing.
Message 3 of 11
Kitsap
Master
The second LED in from the right side (Wi-Fi), is a combination indicator/switch.  With the router powered on and booted up, press and hold the LED indicator/switch for a few seconds and then release.  You might have to do this a couple of times if the boot process produced an error.  After a couple of attempts you should be able to turn the Wi-Fi radios on and the resulting indicator LED should be white (light blue) in color.
Message 4 of 11
Capellam44
I pushed the button several times over the course of an hour or so. With the WiFi light still red. I turned the router off for a few minutes then back on, still nothing. So I pushed the button once more just to make sure. Do I need to connect the computer again before it turns blue?
I used the nighthawk app went to settings and used smart connect but it never could find the router. The app, to me, is lacking some information and functions.
Message 5 of 11
Kitsap
Master
The manual Wi-Fi on/off button, pushed and held down for several seconds prior to releasing?
The Nighthawk application is of little or no value for configuration or troubleshooting.
How many years have you been using this R7000?
Are you comfortable your power adapter is in good condition along with the power source where you plug it in?
Are you sure you have the appropriate power adapter for your R7000?
Message 6 of 11
Capellam44
We purchased the r7000 back in 2019. It was plugged in behind the piano with provided cords. The piano is along an outside wall so we leave an 18 inch gap and it has not moved. Other than using a vacuum wand to collect dust bunnies, the cords are undisturbed. To be sure we did get a new Ethernet cord to go between the wall and router.
Message 7 of 11
Kitsap
Master
Repeat question:  The manual Wi-Fi on/off button, pushed and held down for several seconds prior to releasing?
Message 8 of 11
Capellam44
Yes. The manual button was pressed down for severe seconds before releasing.
Message 9 of 11
Kitsap
Master
Time to declare your R7000 a casualty and look for a replacement.
Message 10 of 11
Guru
Try a 30-30-30 reset on the router?
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2162 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
