AR_0991's avatar
AR_0991
Tutor
Jun 02, 2022
Slow WiFi Speeds (R6700)
I recently noticed slower speeds over my wifi network. I ran a speed test and saw that I was getting <50% of the speed I am paying for (i.e., ~200 Mbps when I pay for 500 Mbps). I had Cox (my internet provider) come out to run diagnostics. Everything was working fine on their end, and my wired connection was as advertised. Thus, I'm assuming it must be the router.
I have tried just about everything: power cycled, factory reset, made sure my firmware was up to date, and adjusted my channel. The only thing that helped with adjusting my channel, but even now I'm only getting an additional ~25 Mbps (i.e., 225 Mbps).
Any other recommendations?
  • plemans's avatar
    Do you get full speeds when hardwired in?
    What device are you using to test speeds?
    What firmware is on it?
    Are you using traffic monitoring, qos, access control, or parental controls? (if so, disable them)
    Is ipv6 enabled?
    • AR_0991's avatar
      AR_0991
      Tutor
      Thanks for the speedy response plemans.
      To answer your questions:
      1. Yes, I get full speeds when hardwired
      2. I have used multiple devices to test the speed (e.g., my Nighthawk App, getmyspeed)
      3. The firmware version is: V1.0.4.22_10.0.95
      4. No, I am not using traffic monitoring
      5. No, I do not have any QoS enabled
      6. Access control is turned off
      7. Parental controls are not enabled
      8. IPv6 is disabled
      Hope that helps narrow it down.
      Thanks again!
      • plemans's avatar
        what actual devices are they?
        225mbps is pretty amazing for a 1x1 antenna device. its a little under performing for a 2x2 device.
        Keep in mind, 2.4ghz is slow and you're not going to even close to 5ghz speeds with it.
        how far from the router are you? 5ghz speeds drop off quicker than 2.4ghz but they have a higher starting point.
