ksuwildkat's avatar
ksuwildkat
Follower
Dec 30, 2023
VPN for R8000
Im looking to instal a router based VPN on the R8000.  I dont want to have to use a client on each device, just a router based one.  I can see how to do that with Open VPN.  I tried NordVPN but they dont support Netgear.  IS there any way besides flashing my router to WRT?
  • plemans's avatar
    microchip8 is exactly correct. They're not supported on factory firmware.
    If you're wanting a VPN, you'd have to flash it with aftermarket firmware. that voids your warranty and can brick your device.
    But I've heard it works well
  • If you choose to flash your R8000 with third party firmware, prior to, be sure and save a copy of the OEM firmware and a copy of your current configuration file.
    Should something go awry in the future, you will use these to return to the OEM configuration.
    Minimal effort to establish a fall back position.
