- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
X10 R9000
- Mark as New
- Bookmark
- Subscribe
- Permalink
internet connection being dropped by x10
Have the latest firmware as of today 9/19/2018
When wired in, no issues
I brought out my much older netgear router running on a different channel, no issues
when connected to my R9000, the router drops the internet connection. The wifi connection is fine, it's just the internet connection that gets dropeed and then back on in about 2 to 3 seconds. happens about 10 times per day. other devices connected to the router experience the same issue as my laptop.
Any idea why the internet connection is being dropped byt the x10? QoS is not enabled as recommended by some posts.
Seems like i'm not the only one expereincing this issue with this router.
Any help would greatly be appreciated.
thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
Access control is on
I've seen posts here where people have done a hard reset and it has not solved the issue.
I guess i can try that next, but I'm not confident that it would help given other peoples experience in doing that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
I've been running with Access Control and QoS enabled so far so good, however, I make no changes on the Access Control page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
other than setting my wifi name and password, all other settings are whatever the factory set.
I waited too long, should have returned it... very frustrating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
Can't say, if its still under warrenty, I would contact netgear
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
I reset to factory setting - same result.
I changed the channel to 161 - fingers crossed, connection has not dropped in the last hour. really hope this does it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
I bought the X10 17 days ago my last router went bad. The X10 contantly drops my Wireless Connections. The internet is faster wireless than wired really don't understand that. I just so happen to find this message board and fine others are having the same problem. You buy the best fancy product available because you want the best and you have dropped connections frequently it's terrible......that is my rant. I have QOS enabled so I will disable and see if that fixes Wireless problem. I updated firmware to 1.04.12. It's has to be still under warranty and I bought the Best Buy extended warranty but you know replacing it with same model not going to fix my issue if it's the product. I'm work from home person on VPN I can't have it disconnecting it stops my software from working. I placed wired connection to my work labtop has not disconnected once.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
I have tried everything that’s been recommended here. The only thing that helped reduce the drops was switching to channel 161.
Hope they resolve this issue someday. This will be my last Netgear router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: X10 R9000
try this, change your 5ghz wifi channel from what it is to something else. 161 has been working great for me so far; no dropped connections in almost a full week now.
The other thing I discovered today was citrix netscaler was slowing down my wifi connection. I went from 180mbps to 425mps just by removing citrix netscaler.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
