SRavetti's avatar
SRavetti
switching to IPv6
im having issues switching from ipv4-ipv6 when i enter the site to get into router setting the user name admin and password password dont work....my xbox wont connecto using ipv4 for some reason , can anyone help me?
  • plemans's avatar
    what modem/gateway do you have?
    What firmware is on it?
    Do you have ipv6 enabled?
    • SRavetti's avatar
      SRavetti
      if you could tell me where to find that info ill glady share, im such a noob with this stuff! i just want to play my xbox on a wired connection lol
    • SRavetti's avatar
      SRavetti
      firmware V1.0.4.100
      modem is from spectrum if that helps
      and no i dont have ipv6 enable as i cant log into the router
      • plemans's avatar
        Is it giving you incorrect password/login result?
        When you first set it up, it asks you to change the password.
        So if you don't know your password, then you'd need to use the password recovery option.
        If you didn't set it up, then you'd need to factory reset to get back in.
