- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to configure EasyMesh devices to work with NightHawk mesh router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see that the NightHawk Mesh routers support EasyMesh. How do you add an EasyMesh device to the mesh? I have tried putting the device in pairing mode using the add satellite as though it were a NightHawk satellite, but that does not work. Thanks for any assistance that you can provide.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
might be cheaper to just add another satellite. I think the MS60 and MS80 are both compatible with it.
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to configure EasyMesh devices to work with NightHawk mesh router
What router do you have?
the only one I know that potentially had it was the MK series but I'm not sure if it was fully part of the EasyMesh standard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you trying to pair the satellites?
You could try hardwiring them in and syncing them.
I've seen that method work quite a few times
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What device is it?
Are the satellites sync'd fine?
What error does the other device give you?
did you contact them to see about different methods of setting up? Sometimes wps doesn't work the best.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are the satellites sync'd fine? All satellites work properly to run the house wifi
What error does the other device give you? No errors, it's just not being found when I go through the add a satellite feature. I think the process is something different for EasyMesh. I can't find how to enable it on the router or how to connect to it.
did you contact them to see about different methods of setting up? Wavlink states contact router vendor for assistance setting up EasyMesh.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try setting the wavlink up in extender mode using its installation assistant.
it'll have the same performance. I haven't seen much push on Netgear's end for easymesh compliance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
