- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MR80 Ethernet Backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I force wired backhaul?
I have the MR80/MK83 router and 2 MS80 satellites. The satellites are hardwired, but only 1 of them is using wired backhaul (it is farthest away/most likely to be out of range of wireless backhaul).
I want to force the other satellite to use the wired connection for backhaul even if the wireless is within a range to be functional.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check the cable.
Take the satellite and connect it to the router with a good quality cat 5e/6 cable that's only like 6 ft long. Give it 5 minutes (to switch over), then check the app/browser.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: MR80 Ethernet Backhaul
How do you know the wired backhaul isn't working?
What does it show when you log in through the browser (don't trust the app)?
Have you tried a different cable between the 2 (for testing, use a short 6ft cable just to ensure its not the cable)
- Mark as New
- Bookmark
- Subscribe
- Permalink
The app shows the wireless icon for 1 satellite, and the wired icon for the other. Also in the app, if I click on the satellites and click details one says 5Ghz and the other says Wired.
On the admin console through a web browser is shows connection type = 5Ghz for one, Wireless for the other.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check the cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good call. Must have been a bad ethernet cable.
Should have been the first thing I checked but didnt have issues (that i knew of) with my previous setup so assumed it was a config with the new setup.
THANKS!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad to see you found the issue!
If its a cable in the wall, a lot of times I'll see ends on them go bad. You can usually snip them off and redo the ends so you don't have to restring the whole cable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was actually the punch to the back of the rj-45 jack. Something must have wiggled loose or something. pulled it out and repunched and all is good and showing wired backhaul now.
