casma164's avatar
casma164
Initiate
May 01, 2022
MS60 satelite dead?
Satellite is plugged into an outlet.  No light.  Pressed the reset for 10+ seconds, no change.   Nighthawk app shows it on the network map, but with a red indicating light and under devices, shows its offline.
Anything I should try before submitting a hardware warranty claim?
  • plemans's avatar
    Try using a power supply from a different satellite or even the router to see if its a power supply issue
    • casma164's avatar
      casma164
      Initiate
      Yeah, its the power supply.  Swapped it with the working one and updated the satellite firmware.
       Thanks for the help.
      • plemans's avatar
        Did updating and swapping back have it working?
        Not sure what netgear's warranty is on power supplies.
        Are you still within warranty? You could check with them if its not.
