- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Since I updated the MR60 firmware in January 2023
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since I updated the MR60 firmware in January 2023, I have had three different times where devices started dropping from the router. Not being very knowledgeable about these matters but able to follow directions, I spent roughly a full work day the first two times bringing everything back online. Yesterday was the third occurrence. In the 17 months I’d owned this mesh system prior to this latest firmware upgrade, I had not had any problems with it. I spent some of last night and most of today following the advice of every thread on the subject. I learned far more about routers than I ever wanted to. All the resetting and rebooting failed. Finally I followed this thread to install the old V1.0.6.116 firmware. Thankfully it worked. I don’t know much about routers and I shouldn’t have to. I installed the mesh system initially following NETGEAR’s relatively easy instructions and it worked well for 17 months. Then a new firmware comes along and it all went to hell. It shouldn’t have taken me this many hours to fix and I should have to go back to old firmware. NETGEAR has a problem with this firmware (just look at the number of threads on the internet about it) and they need to fix it. Based on this experience I’d be hesitant to buy another one of their routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Since I updated the MR60 firmware in January 2023
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How was the system updated? Manually or using the Nighthawk app?
Did you first update the MS then the MR lastly?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between MR and MS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/000061709/Where-should-I-place-the-Mesh-WiFi-satellite-of-my-Nighthawk-Mesh-W... 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
I've not seen any issues with current version of FW loaded. Factory reset and setup from scratch with mine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the response. I read many of your posts on other reads while researching the issue and followed all the steps you, and others, recommended. None worked until I reinstalled the old firmware and then - poof - like magic, everything was good again - no fiddling with settings, no having to have a computing degree. Just simple. This highlights my issue - a firmware update should be simple. It should not require someone to spend hours researching and trying different things. If it's that hard, then something is wrong. Appreciate all the advice you've given me and others! Here's hoping the next firmware update doesn't require a visit to this forum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's how it works 99% of the time.
Every now and then – and a bit too often recently – rogue firmware escapes through quality control and dumps people in the mire.
When there is new firmware, it can be a good idea to wait and see if people report problems. If so, wait for a fix.
Experienced users also like to control what happens by doing a manual update:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Something tells me that you will be just fine in future. You are now a member of the "been there, done that" crew.
You might also like to try this:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Next time, please give feedback to the questions presented as there could be other factors that are causing problems.
I for one have not seen any issues with this current version of FW with my MK63. Works great for me.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the support!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Support involves detailed troubleshooting based on knowing as much as possible about the network involved.
This is a user-to-user group. Most of the people here don't work for Netgear, but they have seen many many problems reported here. So they know the questions to ask.
If you don't want to provide the requested details, there's not much that anyone can do.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
