mikeebee
Apr 18, 2021Aspirant
Anyone find stable R7300 firmware config after 1.0.0.68?
I am unable to find a stable firmware upgrade beyond 1.0.0.68 for the Nighthawk R7300 router. I've upgraded it each time, the latest try to 1.0.0.74_1.0.29 and have been met with unstable connections each time. We get intermittent dropped or slow connections from all of our devices in the house. I even tried rebooting the router each morning, but that did not help. This instability does not happen on .68.
Normally I would leave well enough alone and just stay on .68, but with each new update, there are new security patches. I'm concerned to be running a version that's over 2 years old now.
Has anyone else been able to update and get stable results? Is there perhaps a setting or specific configuration that is causing the problems?
- DarrenMSr. NETGEAR Moderator
Have you tested the connection on the modem to see if it is stable?
DarrenM
- mikeebeeAspirant
Not sure what you mean by this, as the router is very stable on .68, it's only the versions after this.
Sorry didn't catch that the first time I read that. So the newer firmware has slower speeds on both wifi and hardline? also, are you having any wifi disconnect?
