aprilt26's avatar
aprilt26
Follower
Feb 16, 2022
Can't connect ethernet
I cannot connect the router to my ethernet connection in one office.  The desktop says make sure ethernet plug is plugged in.  It is.  Tried several ethernet cables and also had the outlet tested and it works.  Any solution?
