saintssuperdome's avatar
Sep 28, 2016
Compatible Modems from Charter for NetGear r7000 nighthawk
Is there a list of compatible modems for the R7000 Netgear Nighthawk?   I have Charter, and I am wondering if the modem is not compatible.
  • Retired_Member's avatar
    Retired_Member
    Sep 28, 2016
    If there is such a list I've never seen it. I would expect any charter supported Docsis 3 modem would work.
    Retired_Member
    • saintssuperdome's avatar
      saintssuperdome
      Thanks.   This router is set up, but once you are connected you can't get out to the internet.
        Retired_Member
        reset modem after 5 minutes connect router then turn it on
