Orbi WiFi 7 RBE973
Reply
Compatible XR500 Mesh Extension
hands4
Which routers work as mesh extenders for the XR500?
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 7
Accepted Solutions
Guru
Re: Compatible XR500 Mesh Extension
routers and extenders are 2 different things.
Pretty much all of netgears extenders will connect to the XR500.
You just have to choose the features/performance that you want. Like the mesh option.
Or triband.
https://www.netgear.com/home/wifi/range-extenders/
Message 2 of 7
All Replies
Guru
Or triband.
Message 2 of 7
Guru
My two EX7700s work well with my XR450.
Message 3 of 7
Guru
Be sure to visit and post over in the Nighthawk Gaming router forum:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-rout...
Good Luck.
Message 4 of 7
hands4
Thanks to all of you. I chose a used EAX15 for $75. It should work well enough for my humble needs.
As far as posing in the Gaming forum, this forum did not ask me to go anywhere else. It simply asked me to start a new thread. I did identify my product as a Gaming router, so should the formum not post in the relavant forum, or ask if I want to do that?
No need to reply. I'm just making and observation and suggestion,
Message 5 of 7
Guru
Message 6 of 7
Guru
Also be sure to visit and post over in the  NH Gaming  Router forum  for the XR series routers:
Thank you.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1554 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
