rakiboy's avatar
rakiboy
Follower
Feb 14, 2017
FTP and VPN acces
Hi There
I need a help to set up a vpn acces and FTP server.
I have R7000 router connected to internet and behind him there is a Qnap NAS server.
I have enabled the option in qnap to have a ftp and also give him a static IP.
In router i have port forwarding to and the vpn address from my provider. With my previouis old router i could connect only through vpn. it was simple thing with forwarding but now I cant and the set up is pretty much the same. I tryed to use ftp but wihtout any luck.
Sorry if I writing some confusing things, but im new to this and i run through many manuals and forums but i couldnt find any help.
Thanks in advance for every advice
  • Also, on FTP you need to make sure the QNAP is configured to use passive FTP with a small port range (perhaps 4 ports for connection), and you will need to forward those ports to the QNAP as well as the control port.
    Most FTP clients will require masquerading to be set on the QNAP in order to connect over the internet.  FileZilla is one that doesn't need that.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi rakiboy,
    1. What VPN server you are using?
    2. Did you open the ports of the FTP server and the VPN server on the router via port forwarding?
    3. What is the firmware version of the router?
    • StephenB's avatar
    • JamesGL's avatar
      JamesGL
      Hi rakiboy,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
