Reply
Help to Remove DD-WRT Firmware from R700 Nighthawk
Thomaslamf
Hi,
Just after some help to Remove DD-WRT Firmware from R700 Nighthawk, I have tried below but it doesn’t seem to work for me unless I’m doing something wrong help would be much appreciated. Thanks
https://kb.netgear.com/19841/Reinstall-the-firmware-on-a-router-without-the-setup-CD-recovery-tool
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 4
Guru
Re: Help to Remove DD-WRT Firmware from R700 Nighthawk
Check on the ddwrt forum. their the experts on removing their firmware from a device.
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 4
Thomaslamf
Ive been trying to register to add a post but, it never works always says the bot code is wrong when its right. @plemans
Message 3 of 4
Guru
Not sure what you expect the netgear forums to do for a ddwrt issue.
Again, use their forums for their firmware. Or your likely to brick your device
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 186 views
  • 0 kudos
  • 2 in conversation
Announcements
