wgoat27
Jan 18, 2021Aspirant
Intermittent connection issues
My internet connection has been spotty/unstable and I have no idea why.
My equipment:
- C7000 – Nighthawk AC1900 WiFi Cable Modem Router (Firmware Version V1.01.32) connected via wall jack
- Spectrum high speed internet (200 mbps)
- Dell Latitude 3470 laptop hard-wired via Dell docking station/hub D3100
- Google Pixelbook connected via Wi-Fi
- Several other devices (cell phones, Fire Sticks, etc., that haven't experienced any issues)
My symptoms:
- Zoom video calls on Pixelbook (Wi-Fi) constantly drop; Zoom displays "connection unstable" notification
- Chrome browser on Pixelbook (Wi-Fi) intermittently returns "err_address_unreachable" error; pages will typically load within a few seconds/minutes
- Chrome browser on Dell laptop (hard-wired) returns "err_connection_failed" error every few days; problem resolves itself upon restart. (This problem seems to have begun when corporate IT upgraded my machine to Windows 10 in November)
- Netgear event log (pasted in full below) shows numerous "SYNC Timing Synchronization failure" errors
What I've tried:
- Numerous power cycles
- Factory reset C7000
- Changed DNS servers from default to Cloudflare
- Changed 5GHz Wi-Fi channel from default (153) to 161 to avoid interference (diagnostics showed several other networks on same channel)
- Spectrum came out last week to test my connection and inspect wiring and other physical connections, found nothing wrong
To be honest I'm totally lost at this point. I don't know if the problem is with my service or with my hardware. If it's my hardware, I don't know if it's faulty equipment or faulty ownership.
Please let me know what other information I can share. Thank you in advance for any help!
Cable Connection:
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Event Log: (I assume 1970 indicates errors that occurred prior to the factory reset?)
| 1970-1-1, 00:07:12 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:13 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:15 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:20 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:22 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:33 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:34 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:35 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:36 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:41 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:46 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:47 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:48 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:48 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:52 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:53 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:07:54 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:00 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:01 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:06 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:08 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:09 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:09 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:12 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:13 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:17 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:18 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:08:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT |
| 1970-1-1, 00:00:45 | Notice (6) | Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 |
| 2021-1-16, 15:00:58 | Error (4) | Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:01:5c:8f:ac:55;CM-QOS=1.1;CM-VER=3.0; |
| 2021-1-16, 15:00:58 | Error (4) | Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=dc:ef:09:fc:66:08;CMTS-MAC=00:01:5c:8f:ac:55;CM-QOS=1.1;CM-VER=3.0; |
| 2021-1-18, 11:40:31 | Notice (6) | WiFi Interface [wl1] set to Channel 149 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2021-1-18, 11:42:35 | Notice (6) | WiFi Interface [wl1] set to Channel 128 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2021-1-18, 14:08:19 | Notice (6) | WiFi Interface [wl1] set to Channel 157 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2021-1-18, 14:09:39 | Notice (6) | WiFi Interface [wl1] set to Channel 161 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
- mattk2006Aspirant
I have the c7000 v2 and have been expericencing all kinds of drops and what seems like DNS issues.
My event log also looks alot like this and I does lead me to suspect that there is an issue with the hardware. I purchase my unit from Amazon, which i think may have been referbished as it was discounted and came in a basic brown box.
As a last ditch effort I am making sure that my wireless channels are free, being only devices are on those channels.
I may cave though anc just go buy a modem from Motorola or Arris.
I have never had these issues when using DSL and an Asus router.
It would be great if there was a way diagnose cable connections and the various errors that show on the logs from Netgear.
- mattk2006Aspirant
Also found this post:
Solved: SYNC Timing Synchronization failure - Virgin Media Community - 4149017
might be an issue with the phyical connectoin or connectors
- wgoat27Aspirant
Thanks for your input, Matt.
The fact that I'm having issues on a hard-wired PC and Wi-Fi-connected Chromebook (as well as my Android phone) tells me the issue is either with the Netgear device or the Internet service itself.
This weekend I replaced my coax (wall to modem router) and Ethernet cable (cat 5E patch to cat 6, now connected directly from the modem/router to the PC) and my problems persist. The only thing that seems to have helped a little bit is moving my Chromebook from the 5G band to the 2.4G band. I've still had drops, though, so I dunno.
I posted a similar thread on the Spectrum user forum. Had a little more engagement over there, but still no solutions. https://community.spectrum.net/discussion/168825/need-help-diagnosing-intermittent-connectivity-drops/p1
