Orbi WiFi 7 RBE973
Reply
My laptop computer does not have an ethernet port.
radio_chas
Follower
My laptop has no ethernet port.  Can I connect to the router via the USB 2.0 port to upgrade the firmware, although it is marked printer on the router?
What other options do I have?
Model: R6700v2|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: My laptop computer does not have an ethernet port.
> [...] download the new firmware to a USB stick and flash from that.
   Please explain what that means.  How does using a USB storage gizmo
help matters?
> Just follow the Release Notes.
   I don't see anything there about a USB storage gizmo.  All I see is
"[...] download and extract the new firmware to a convenient place such
as your desktop."
> You can upgrade firmware over wifi.
      Firmware upgrade instructions:
      Note: To avoid disconnect issues during the firmware download
      process, NETGEAR recommends the firmware update be performed on a
      computer with wired connection.
Message 4 of 4
All Replies
antinode
Guru
   What is your "My laptop"?  Can you attach an Ethernet interface to
it?
   It won't work.  The router firmware supports only printers and
storage (not networking) on the router's USB ports.
   Make friends with someone whose computer has an Ethernet port?
Message 2 of 4
No.
You can upgrade firmware over wifi. If that worries you, then download the new firmware to a USB stick and flash from that.
R6700v2 Firmware Version 1.2.0.16 | Answer | NETGEAR Support
Message 3 of 4
antinode
Guru
help matters?
as your desktop."
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 8189 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
