Greg_Mouchyn's avatar
Greg_Mouchyn
My router is choking my internet speed
Hello Folks,
My router is slowing down my internet speed.
I have a 400Mbit/40Mbit setup, and have verified that speed at the modem.
But on the router side it is choked down to 160Mbit.
I am running firmware 1.0.4.120_10.0.91.
Is there a reason, or a fix for this?
Thanks,
  • plemans's avatar
    1. what router do you have?
    2. what modem/gateway do you have?
    3. make sure qos, access control, traffic monitoring, and parental controls are all disabled and reboot the device?
    • Greg_Mouchyn's avatar
      Greg_Mouchyn
      I have the R6400v2.
      Cable modem DOCSIS 3
      None of that is on.
      It was working at the specified speed and now doesn't.
      I am guessi g when I did the firmware update, that broke it.
      Now I can barely get 200Mbit throughput.
