- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NAT Loopback on r7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do not seem to be able to get NAT Loopback to work on th R7000 I have purchased precisly to enable that.
Can you help.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't believe stock or OEM FW supports Loopback
Try this
http://www.linksysinfo.org/index.php?threads/asuswrt-merlin-on-netgear-r7000.71108/
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try this
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NAT Loopback on r7000
Thanks for this. Just bought it specifically for the NAT Loopback. I will look at your suggestion. Do you know any routers that do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. I will seek that or then try the third party route as you suggest.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both port forwarding and NAT Loopback working. Managed to get it working on the Talk Talk network with TV in the UK. I have not checked out everything. The Router seems to be working well.
Thanks again.
