- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk Connection Options
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am considering purchasing a Nighthawk R7900P. My Spectrum 1G cable modem is upstairs in a small loft and I have a 16 port Netgear Gigabit switch beside the cable modem with ethernet feeds to most of the rooms in the house.
Almost all of our internet connections are initiated from the first floor of the house. What I would like to do is connect the cable modem to the Gigabit switch and then locate the R7900P on the first floor and connnect to one of the ethernet feeds on the first floor.
Will that work or do I have to connect the R7900P directly to the Spectrum cable modem?
Thanks in adavnce for your help.
Nick
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
A more normal, arrangement, and one that I use, is to go:
> modem > router > switch
In that way the router gets to manage the traffic through the ports on the switch.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk Connection Options
> [...] My Spectrum 1G cable modem [...]
Not a very detailed (or accurate) description of what must actually
be a modem+router. (Generally, an actual maker and model number would
be more helpful.)
> Will that work [...]
I don't see why not, if it's done properly.
Visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual. Read. Look for "Set up
the router as a WiFi access point".
> [...] or do I have to connect the R7900P directly to the Spectrum
> cable modem[+router]?
Nah. So long as you don't connect a network switch to an _actual_
modem, or have two routers (both acting as full-function routers), then
inserting a network switch between the main (modem+)router and the
R7900P-as-WAP should be harmless.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. The Spectrum device is a cable modem only. It is not a router. It is made by Hirtron. I think the model number is E3IN2V1.
I am currently using using a Velop mesh network that is currently connected directly to the Spectrum cable modem. The primary Velop node is then connnected to my Netgear switch. I want to replace the Velop.
My original question still stands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> connected directly to the Spectrum cable modem. [...]
Thanks for not wasting everyone's time with a sloppy/incomplete
problem description?
You need to connect the (really-a-)modem to the router WAN/Internet
port, and the network switch to a router LAN port. Whether that's
possible/practical/convenient with your current cable arrangement is
another question.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. Sorry for wasting your time
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the reply. I figured that was the best option. I wanted to place the Nighthawk router downstairs. Right now the cable for my Spectrum modem is running to the loft on my second floor.
The only way I am going to be able to do this is if I re-route the cable for the cable modem downstairs as well and move both the cable modem and the router downstairs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> A more normal, arrangement, [...]
> [...] the router gets to manage the traffic [...]
It's not a question of "more normal" or "manage the traffic"; it's a
question of works or not.
> port, and the network switch to a router LAN port. [...]
Still true.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you have Ethernet cables running around the place. So you shouldn't have too much trouble plugging things in to get the best result, even though it may mean crawling around in the loft.
One important factor might be that it helps to get the wifi source in the middle of the property.
You seem to have that in mind with getting the R7900P on the first floor.
The R7900P should fill a reasonable space.
Hope it works out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> result, [...]
Except for the minor problem of having the modem and the network
switch in one place, "the loft", and the router in another place, "the
first floor", which would necessitate running two cables between the
stuff in the loft and the router on the first floor.
So, sure. Not "too much trouble" at all. (For anyone who doesn't
have to run the additional cable.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was in the attic today poking around and realized I have coax running to 4 or 5 rooms on the first floor that I used for Directv. I no longer have Directv.
This means I can move the cable modem and the new router to a single room downstairs. It will be fairly easy to connect the existing coax cable for the cable modem to the old Directv coax that is alreay in place. After I have the cable modem and the new router in the downstairs room, the only other task I have to perform is to run a 40' ethernet cable from one of the ethernet ports on the back of the router back up to my Netgear GS116 switch in the loft. I have too many ethernet feeds to move my switch anywhere else.
See anything missing with this approach? Any issue with a 40' ethernet run to my switch?
Thanks for all the help.
Nick
- Mark as New
- Bookmark
- Subscribe
- Permalink
> room downstairs. [...]
That should work. (A careful reader might note that I wrote, "two
cables", not "two Ethernet cables".)
> [...] Any issue with a 40' ethernet run to my switch?
For Ethernet, anything up to 100m should be ok. What could go wrong?
A pessimist might check the signal stats on the modem at its old
site, for comparison with what happens at its new site. If there's a
problem with the new/different/extended (co-ax) cable, then more info
might make blame assignment easier.
