Orbi WiFi 7 RBE973
Reply
Nighthawk R6700v3 PPPoE setup for Fidium fiber?
future_vision
I have new Fidium service but opted to use my Netgear Nighthawk R6700v3 router instead of their router which I understand is pretty locked down. Problem is I can't seem to get internet working over Wifi or Ethernet. I have my PPPoE credentials and the routers says internet service is good but all of the switches > PC's and wireless devices cannot access the internet. We're moving over from Xfinity using a cable modem so maybe there is some setting from that setup I need to clear? Maybe I need the most recent firmware(I am actually using a older version on purpose with Xfinity since a new version, at the time, degraded performance.)
Message 1 of 8
Guru
Re: Nighthawk R6700v3 PPPoE setup for Fidium fiber?
Try using DHCP instead of PPPoE on the NG router...
Message 2 of 8
future_vision
Firmware Version
V1.0.2.52_1.0.39
Fidium ONT
AdTran SDX622v XGSPON ONT
Supposedly authentication happens with PPPoE. They are switching over to MAC and serial in the near future.
Message 3 of 8
Guru
Can they move the PPPoE to the ONT and then let the NG router use DHCP?
Message 4 of 8
future_vision
I don't believe so. I'm not even sure I can access the ONT
Message 5 of 8
Guru
For this kind of ISP service, the R6700v3 is using older generation hardware so even if you got this to work, it may not work well or to spec. I would recommend you get into a newer generation router to use with this ISP service.
Message 6 of 8
future_vision
Any recommendations?
Message 7 of 8
Guru
I've heard good things about the RAX30 and 40 series routers working well.
@microchip8
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2926 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
