- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 flashing white power led
- Mark as New
- Bookmark
- Subscribe
- Permalink
I made the mistake of updating my firmware and now my router is unusable. My router is a nighthawk R7000. I am currently running windows 10 on my desktop. I logged into the router and click on update firmware to the latest version. It was taking a while, then it restarted and started flashing the white power LED. I was waiting an hour and a half before giving up. I restarted the router with no change. I have tried the reset button with out any success. The reset button does nothing if i hold it down for 8 seconds or 1 minute. I have tried disconnecting the power from in for a few minutes with out success. I have tried Netgears "support" page that shows how to install new firmware. It only gives support for windows xp and 7. I tried following it the best I could but tftp-i is not a command for the cmd. Another page recommended that I use tftp2 however that did not help either. Is there a way for me to save it or did Netgear fry it?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found a step by step forum that worked for me. I had tried tftp on my computer as well as tftp2 that was recommended by another forum. This other forum recommended using tftp -i on however what I didn't know was that you have to first enable/install software in windows for it to work. The forum I mention is "https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-...". Thank you for helping me fix the firmware problem.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 flashing white power led
There is one other reset option that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
You referred to TFTP. Did you read this?
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
There is nothing in there to suggest that it won't work in Windows 10. The date on it is in the era of Windows 10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for giving me another option sadly though, it didn't work. I followed your instructions for resetting it. This time the reset switch did seem to restart the router. When i let up on the switch it seems to boot up then start flashing the white power led at me like before. The article you linked is the one I tried. Every attempt to run the tftp2 I just get the error "unable to get responses from the server." I can ping the router using cmd. I have tried the default password as well as my current password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you can ping the router you may have a chance of saving it you will need to reflash its firmware netgear has the instructions on its https://www.netgear.com/support/ link.
Follow the directions as lay out if you lose the lan ports as access point to the router you will be forced to use a serial cable connected to routers main board.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I have tried Netgears "support" page that shows how to install
> new firmware. It only gives support for windows xp and 7. [...]
Which 'Netgears "support" page' was that? The differences between
Windows 7 and Windows 10 are not great enough for that to matter much in
a case like this.
> [...] but tftp-i is not a command for the cmd.
Did you leave out a space? "tftp -i", not "tftp-i"? On most
command-line interfaces, space characters are used to separate commands,
options, parameters, and so on. And "-i" looks like an option.
> either.
Which "Another page" was that?
"did not help" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, ...)
can be more helpful than vague descriptions or interpretations.
> [...] I have tried the default password as well as my current
> password.
If you've done the full ("factory") reset, then your "current
password" is now your former password, and the default password is now
the real password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You has some very good videos on how tffp the netgear r7000 router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the exact same issue. I have tried the reset button, the 30 second reset button reccomended in this thread. I have tried tftp through the command line and it seems like it is working and restarts the router but as soon as it boots its back to flashing the power led. I also tried using tftp2 as outlined in this article, this one just comes up with a "unable to get responses from the server" error. I can ping the router just fine but nothing else. Wonder if there is a problem with the newest firmware for this model.
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@William10a wrote:
If you can ping the router you may have a chance of saving it you will need to reflash its firmware ...
That's my understanding too, but that link takes us to the main support page.
Did you mean to point at a specific article?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Excellent.
Netgear needs to write a better KnowledgeBase article on how to fix this issue.
Fortunately, now that this is flagged as Solved it might help later victims.
