Harmlessluv's avatar
Nov 30, 2021
Nighthawk R7000p no internet connection
Hi guys, so I set this router up 4 months ago (can't remember how I did it either). I was told to reset it by my internet provider which has led to no internet connection on the router login website aswell as a constant orange light for the internet.
I've tried manually setting it up, I inserted the details given by my service provider but nothing seems to be working. Is anyone able to help me out?
  • plemans's avatar
    What modem/gateway are you connecting it to?
      • plemans's avatar
        You look at what you're plugging the router into that supplies an internet connection. There should be a label on it.
