Orbi WiFi 7 RBE973
Reply
Nighthawk R8000 x6 New firmware issue V1.0.3.54_1.1.37
Routermania17
Hi everybody,
I just updated to the last versionof firmware my router but i noticed that with the 5 GHZ band devices keep disconnecting..
Anybody has this issue ?
Thanks.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 17
Accepted Solutions
JamesGL
Master
Re: Nighthawk R8000 x6 New firmware issue V1.0.3.54_1.1.37
Message 15 of 17
All Replies
JamesGL
Master
Hi Routermania17,
Try changing the channel of 5Ghz. If still the same, reset and reconfigure.
Message 2 of 17
Routermania17
Thank for your email James GL. Do you believe a new firware could still be available soon ?
Message 3 of 17
Routermania17
I tried everything but nothing...
Hope for a new firmware..
Message 4 of 17
JamesGL
Master
Hi Routermania17,
The issue on both 5Ghz-1 and 5Ghz 2?
Message 5 of 17
Routermania17
Spoiler
Now the issue seems to be related to thevery slow connection of the  provider.
Message 6 of 17
Routermania17
I experienced this issue now :
Tried to connect to the 5ghz via iphone and ipad and it gave me password incorrect. I tried instead to connect to the 2.4 ghz and it worked..
I combined together the 2 different 5 ghz bands in one unique...
Message 7 of 17
AllyComm
Initiate
We upgraded a client to this firmware today and are also experiencing multiple and frequent disconnects on WiFi. We are going to have to roll back to a previous version.
Message 8 of 17
LopezZondek
Having the same issue. Resetting the router a couple of times a day to keep the wifi working. Is there any way to notify Netgear directly that this is an issue?
Has anyone tried the DD-WRT firmware?
Message 9 of 17
Routermania17
I tried to connect to the 5GHZ band  but it said wrong password even though it was correct..
I tried to connect 4 times typing the password till it connected.. Anyone experiencing this issue ?
Message 10 of 17
JamesGL
Master
Hi Routermania17,
Forget the network first on your device or change the name of your 5GHz network.
Message 11 of 17
Irish3211
Hello All,
Here is my issue, I have the latest firmware update and since that update I have had a terrible time staying connected or getting any of the download or upload speeds I am paying for.  I had an Xfinity guy come out and dissconnect the router and test the modem and am getting on avearge download speeds of 250mbps and uploads of around 11 - 12mbps.  Once we connect the router it drops to 40mbps - 60mbps,
I have reset the router, I have disconnected everything and redid set up and still the same issue.  I have talked a a few trusted colleauges and they mentioned the latest update Version:1.0.3.54_1.1.37 is causing these issues and I need to rollback to the previous firware release.
Any advice or reccomendations would be very helpful. Thanks
Brian
Message 12 of 17
JamesGL
Master
Hi Irish3211,
Can you post the statistics of the WAN port.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Message 13 of 17
Routermania17
With the latest firmare  V1.0.4.2_1.1.41... I got the same issue of disconnecting from the 5GHZ band saying that the password is not correct even if it retype it correctly..
Message 14 of 17
JamesGL
Master
Hi Routermania17,
Here is the latest firmware.
https://kb.netgear.com/000052298/R8000-Firmware-Version-1-0-4-4
Message 15 of 17
JamesGL
Master
Hi Routermania17,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 16 of 17
Routermania17
It seems the new firmware solved the issue.
Thanks for the support.
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 6073 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
