helpmeplease12's avatar
Dec 13, 2021
No internet after firmware upgrade and factory reset R7000
Hello!
I recently upgraded my R7000 to the latest firmware (1.0.11.128) as of last night and per recommendations, performed a factory reset on the router, including powering off my modem, waiting for that to restart and then booting the router back up.
After resetting the router, I have no wifi. All lights on the router are solid white, making it seem like there should be a wifi connection. My phone, laptop, and smart TV can all “connect” to the wifi, but when trying to load something, all three say there is no internet connection.
I do not have the ability to do a hardwire test to the router.
Please help. I am at the end of my rope.
Update: tried connecting through the NightHawk app on my phone and it says the router is disconnected.
Update 2: all lights on the router remain solid white. The app is saying it can no longer find my router.
  • plemans's avatar
    Push and hold the wifi on/off button for 2 seconds.
    sometimes that gets hit while people troubleshooting devices.
    • Thank you for the reply! I just tried turning the wifi button off and back on and there was no luck. Cannot even find my network in my wifi settings on my iPhone now.
      • plemans's avatar
        Know anyone with a laptop/pc you can plug into the router to check if its working as well as what its ssid/password is?
        They also make usb/ethernet adapters.
        When you reset, did you push and hold reset for 7-15 seconds while powered on?
        If so, the wifi should be the default ssid on the sticker.
