Izkiz
Aug 16, 2020Tutor
R6700 bricked after firmware version 1.2.0.72
Hello...
I update my router R6700v2 to the new firmware versión 1.2.0.72 and it crash my router.
Is bricked and i can't acces to my router.
I try everything on the internet, TFTP, and others solutions and nothing happends. Still bricked.
I can't ping my router, i try it and nothing.
Any help? or i need to get new router?
tftp has many steps that can fail.Make sure to follow exactly (even punctuation). there's even a video to watch to help see how its done.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- wcalifasProdigy
What tftp method did you use? Did you download the program tftp2.exe to do it? If you tried a different way I suggest you use that tftp2.exe program to do it. Try pressing the reset button for a second or two and run the tftp right after you press it.
- IzkizTutor
yeah, i use tftp2.exe, cmd tftp, tftpd64 and nothing... i press the reset boton, i try to connect my router with static ip and sending ping to default gateway and no connection...
i don't know what to do, i just accept a netgear update and my router crash...
What symptoms do you see? What do the LEDs reveal?
Bricked is one of those terms that get thrown about, often wrongly.
It is not necessary to resort to third party TFTP software. Dangerous and maybe less capable. Windows does it.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
- IzkizTutori only can unlock 2 type of leds
1- when the router is off, i press the reset button for 30 seconds and i turn on the router... the power led start at color amber /orange and the port of my computer white, then all ports leds off and power led star blinking in white.
2- when i restart normally my router, the power led in orange / amber and my pc port in white.- michaelkenwardGuru - Experienced User
2- when i restart normally my router, the power led in orange / amber and my pc port in white.Sorry, it still isnlt clear to me.
Let's keep this really simple.
After you have turned the thing on and it has finished the startup cycle, what does the power LED look like? That's the one on the top on the left.
What colour is it? White or amber?
Is it solid or blinking?
The rest don't matter at this stage.
