Isaac2156's avatar
Isaac2156
R7000 Packet Loss
It all started when I hopped on Fortnite with a couple of buddies. I was in a game with them and all of a sudden, it shows that I have severe packet loss and I lag so much on there. Now, the packet loss now affects my Phone, my laptop, etc. Keep in mind that before I hopped on Fortnite and such, I didn’t have any trouble with lag nor packet loss. I’m already on Firmware Version .42 for your information. Can anyone help me fix it? Is there a solution for not getting packet loss and great speeds? I like to game and I pretty much can’t on everything such as my Xbox, laptop, and phone.
  • plemans's avatar
    Is it happening on wired and wireless?
    What modem/gateway do you have?
    Have you checked the modem's connect? direct connect the modem to the xbox and see if you still have the same issue
    • Isaac2156's avatar
      Isaac2156
      I am wireless, no clue about wired. I do have a NETGEAR Cable Modem CM500. What do you mean by checking the Modem’s connect? Connect the modem to the Xbox?
      • plemans's avatar
        yes, try it with the xbox directly connected to the modem. That helps determine if its a router issue or a modem/isp issue.
