Belloh01's avatar
Belloh01
R7000 with DGND 4000 as modem
I am considering to buy the R7000 AC 1900 Dual Band WiFi and to download the ExpressVPN App. Currently I have my ADSL line linked to the DGND 4000 modem router. Will it be ok, when I link the the DGND as “Modem only” -device to the R7000? Does the R7000 accept ADSL? I am asking, because I have just experienced, that some router support only VDSL.
  • Thank you for your reply. My ISP is MWEB in South Africa. The connection is via PPPoE.
    Before, I tried the Asus R AC68U. It did not connect to the internet. According to the Asus technical support the router does not link to ADSL, only to VDSL
    Nevertheless i am going to buy the R7000 and give it a try.
  • > [...] Currently I have my ADSL line linked to the DGND 4000 modem
    > router.
       Who is your ISP?  How is the DSL connection configured?  PPPoA?
    PPPoE?  Other?
    > [...] Will it be ok, when I link the the DGND as "Modem only" -device
    > to the R7000? [...]
       It depends.
    > [...]  Does the R7000 accept ADSL?
       Generally, I don't think that it cares about the DSL details.
    > [...] I have just experienced, that some router support only VDSL.
       Not a very detailed description of anything.
       As the DGND4000 User Manual and BASIC > Internet page ask, "Does Your
    ISP Require a Login?"  If so, and you (and your ISP) are using PPPoE (or
    PPTP, or L2TP), then an R7000 should be happy enough.  If you're using
    PPPoA, then I doubt that you can use a separate modem and router.
    (Certainly, the R7000 User Manual does not mention PPPoA.)
    • Belloh01's avatar
      Belloh01
      • antinode's avatar
        antinode
        Guru
        > ADSL, only to VDSL
           I looked quickly at the "ASUS RT-AC68U user's manual in English", and
        the only reference to "DSL" I found was:
              Check the status indicators on the ADSL modem and the wireless
              router. If the WAN LED on the wireless router is not ON, check if
              all cables are plugged properly.
        http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC68U/E14013_RT-AC68U_manual_v2.pdf
           Still true.
