Dheeraj1
Nov 29, 2020Aspirant
R8000 Nighthawk X6 AC3200 kicks off all devices every few hours
Hi all,
For the past few months, my router has periodically (every few hours) been kicking out all the devices connected to it. While some devices, especially phones, connect back almost instantly, others, especially PCs, take far longer (up to an hour) to reconnect. When I try to connect back, the devices that refuse to connect back say "Unable to connect to network" but the router still shows up on the list of available wifi networks to connect to. Then randomly after some time of constantly trying to connect to the network, it reconnects and all is fine until after a few more hours (or minutes) the exact same thing happens.
Restarting devices and turning wifi off and on does not let the devices connect back to the network (they still say "Unable to connect to the network). Factory resetting the router didn't help. Also, this didn't use to happen when I just had my Virgin Media router on its own.
Any help would be much appreciated.
Model: R8000 Nighthawk AC3200 Tri-Band
Firmware version: V1.0.4.62_10.1.74 (latest)
Thanks,
Dheeraj
I haven't been a fan of the firmware on the R8000 since they added in netgear armor.
I'd recommend dropping back to version 1.0.4.28 of the firmware. After downgrading, factory reset the router and do a clean install (not from a backup). Disable auto-updates after that.
See how it performs like that.
