- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readyshare not working in AP mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
because i am using my r7500 as a ''second'' router i put it in AP mode.
after i did readyshare stopt working !! is it not possible to use readyshare in AP mode ??
that whould be a major let down !!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
apparently after you put it in AP mode you need to ''restart'' the router before you can acces Readyshare.
after i powerd off my router and turned it back on everything worked just fine
feel so stupid right now....... such a simple ''fix''
thanks for all the help and quick responses tho !!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Readyshare not working in AP mode
Hi @Retired_Member
Welcome to the community!
How do you access ReadySHARE? Is it through wired or wireless computer?
Are you using R7500v1?
I have the setup right now and I can still access the ReadySHARE through a computer that's connected behind the R7500v1 using \\readyshare\USB_Storage
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
sorry for the delay, but i had givvin up.
i will try it now again, i am accesing readyshare wired and wireless ( both not working )
when i get the router back out of AP everything works again.
i have the R7500 V1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear genie doesnt see my HDD anymore aswell
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the ready share setup greyed out when using AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My 2 cents
if this was setup in router mode and then changed to AP mode would the IP change be the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
but i am not searching on IP.
Netgear Genie also doesnt find it
\\readyshare doesnt work
- Mark as New
- Bookmark
- Subscribe
- Permalink
But will it work through IP?
Mine works ok.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're welcome!
Glad to hear that it's all working now.
Do not forget to mark the solution.
