Mike-Mass
Oct 30, 2021Aspirant
Rocket internet speed, wifi sucks
So all of a sudden, my wifi speed is down to slower than a crawl 20-30 mps. My wired speed on my Mac is thru the roof as it always has been, but I'm trying to stream (anything) on my smart TVs and all I get is 20-30 seconds then a "Loading" still picture for 20-30 minutes. My equipment hasnt really changed nor has my various smart TVs and/or smart devices.
So not one of my smart TVs seem to be able to stream anything including YouTubeTV which is my provider. But Prime, Netflix, YouTube videos.. all stop dead and say theres a problem or just a frozenscreen saying loading. Should I do a factory reset and start from scratch?
Mike
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the distance between the router and the TV?
Ensure the TVs system is up dated as well.
Is Smart Connect enabled on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mike-MassAspirant
Hi Fury...
So I got fed up (I'm a grumpy old senior LOL) and did a factory reset. After I did the reset, I was asked if I wanted to update the firmware and I said YES... so thats done. I wasn't sure how to force the router to tell me its firmware version but I eventually found it was V.1.0.2.84.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Its an ARRis SURFboard SB8200 DOCSIS 3.1 Gigabit Cable Modem, and my provider is Xfinity/Comcast.
The Kitchen TV (Samsung Smart TV) is about 25 feet from the router.
This I'd have to check on to see whether this TV self-updates or whether its even capable of updating.
I did not select it to be enabled... should I ?
This I havent been able to figure out, can I do that on the Nighthawk App? Or do I need to do the login on a browser?
Any Wifi Neighbors near by? If so, how many?Yes... when I look on my phone for networks I see a couple of neighbors, One I know is across the street, but houses here are on 1/3rd to 1/2 acre lots so I don't think thats problematic is it?
I can't find anything called Beamforming on the login browser.
Thanks for taking the time to respond. I'm 78 and not terribly tech-oriented but I learned to follow instructions pretty well in the military! So go easy on me LOL... simple laymans language that I can follow.
Mike
Mike-Mass wrote:
Hi Fury...
Can try this. If it's not enabled, it the TV connected to the 2.4 or 5Ghz SSID radio?
Need to log into the routers web page using a PC and web browser to change this.
Should be ok then. Just as long as the router is not using same channels as your nieghbors.
Ok.
Your doing great.
