- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router throttling speeds?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have both a Nighthawk modem and Router(R6700v3). ISP internet is 600-700mbps. When i hardwire my laptop directly into the modem, I get these speeds. however, anything plugged into the router itself gets a max of maybe 250mbps including the same laptop using the same ethernet cable.
Any settings or suggestions to fix this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router throttling speeds?
Model number?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nighthawk Router Firmware version is V1.0.4.84
Modem is NETGEAR Nighthawk Cable Modem with Voice - CM1150V - dont know how to check firmware version on that, however as I said hard-wiring other devices into that directly achieves speeds that I am supposed to get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK. Not a modem/router. Forget about its firmware. It is beyond your control.
Check that you do not have QoS enabled on the R6700. Traffic metering, parental controls and other stuff that puts a strain on the R6700's processor can also cause slowdowns.
I haven't seen a flood of reports of issues with that version, but you could try going back a version or two to see if it helps.
When you try different versions, it can help to do a factory reset with the new firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All QoS settings are unchecked and most settings are defaulted from reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SgtWorm wrote:
Don’t know if it is the armor or what, but every update after that throttles at 250 even on a FIOS connection.
One possibility on thatr front is that this Armor stuff eats into the router's processor power. After all, it means that the router has to "police" the traffic that flows through it. That needs work.
In the past, one solution to "my router is slowing me down" complaints was to turn off QoS, traffic metering, logging and anything that take processor power. Now they have slapped on another layer of complexity.
In an attempt to shoehorn Armor into the router's memory, Netgear has also removed various features, such as media servers. someone of a suspicious mind might jump to the conclusion that these things are under powered.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can someone wake me up when they have a new update that doesn’t destroy the capabilities of their hardware?
