Just635
Dec 04, 2021Guide
Trying to open port 44158 on X4S R7800
I have spent countless hours trying to open port 44158 for my Helium miner on my R7800 router and I believe that I have done everything correctly and the port still shows up as closed.
I have set my miner to a static IP 192.168.1.200 on the router. I set up port forwarding with protocal TCP and the external and internal port range as 44158 on192.168.1.200. I have had UPnP on and off. I have called my ISP to make sure that there is no firewall on their end and they have told me two separate times that there isn't. I swapped out my cable modem to from my ISP's to one that I bought previously to make sure that isn't the problem.
Nothing seems to work and I am going nuts. Any help on how I can get this fixed would be greatly appreciated.
