jon9595's avatar
jon9595
Follower
Oct 23, 2019
Wi-Fi Disconnects when connecting Ring Stick Up Battery Camera
Model: RAX40
Firmware: V1.0.2.60_1.0.1
Hello,
Today, I received  the new Ring Stick Up Battery Camera, and tried to connect it to my 2.4 GHz network on my nighthawk router. Every time it tried to connect it failed. I noticed that every time it tried to connect, that all other devices (the TV, my laptop, and all phones) would temporarily disconnect from the Wi-Fi. I tried resetting the router and the camera, with no luck. I then thought it could be some sort of interference from the camera, because during the setup phase, it broadcast its own network to complete the setup. I tried adjusting the channel on the router to the recommend channels by Ring, with no luck again. They also suggested enabling the guest network with a different SSID, which also did not help. The one thing that was consistent, was that every time it tried to connect, the Wi-Fi to all other devices (2.4 and 5 GHz) would disconnect for a few seconds. In addition, the light that glows green when there is Internet access would go dark for these few seconds. I don't really know how a device connecting to the router could crash the network output, but it seems to be on the router end. I was able to get the camera connected with an old router, just to rule out the camera being faulty. Any help is much appreciated!
