- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi range on Netgear Nighthawk Pro Gaming XR500
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi range on Netgear Nighthawk Pro Gaming XR500
I did look at the WiFi extended device but I though this Netgear XR500 is good enough for a standard house WiFi range. hmmmm..
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any advise is appreciated. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for the NH Gaming router products. Most of the people who watch that forum are more likely to have experience with NH Gaming routers and know how to work it better than those of us who follow this "router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-rout...
If you need additional wifi range or coverage, Ive found that EX7700/8000 wifi extenders work well with XR series routers.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What size is the home and what are the interior walls made of?
Thats key.
Another key is placement.
The routers antennas broadcast omnidirectional and if you're router is located to one side of the home, half your coverage isn't getting used as its not directional. Any chance you can centrally locate it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you so much. Will look into that for sure.
