OBoy's avatar
OBoy
Tutor
Jul 10, 2021
reset remote
Trying to reset router remotely.
I have password but when I enter admin and  the password it takes me to a screen asking for the router serial number not to a reset option.
I dont have the serial # at remote site to enter.
Help please.
    • OBoy's avatar
      OBoy
      Tutor
      when I use app on my phone on T-Mobil it says R7000 Disconnected and list serial #
      • > Trying to reset router remotely.
           "Trying" _how_, exactly?  Why?  Did it stop working properly?
        > [...] when I enter admin and  the password it takes me to a screen
           "enter admin and the password" into _what_?  What, exactly, are you
        doing, from what, where, connected to what, how?
           Generally, these routers ask for a serial number as part of a
        password-recovery scheme (which does not always work).  Which suggests
        that you're providing a bad password.
        > when I use app on my phone [...]
           Have you used "app" successfully before?
