- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wifi not working r6700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I called my cable company to troubleshoot and they couldn't find a problem on their end. The Nighthawk app shows "Internet: Online" but I can't connect to perform any troubleshooting or updates.
The router is r6700 AC1750. On the face of the router only the first 2 lights are lit. Any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed on the router?
Normally modems and routers are designed to be ON and online 24/7. There would be no need to turn them off each night. Doing this maybe causing hardware stress and faults.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wifi not working r6700
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
