- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AX6600 router and want to connect 2 ethernet cables to 2 different computers
- Mark as New
- Bookmark
- Subscribe
- Permalink
I want to connect 2 of my computer towers to the one router, but only one will work.
Any suggestions how to get both of them connected?
thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AX6600 router and want to connect 2 ethernet cables to 2 different computers
What model# router do you have? RAX###?
Check ethernet connections and configurations on PCs. Update ethernet drivers on the PCs.
CAT6 LAN cable is recommended.
Check LAN ports in back of the router, try all LAN ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tell us more.
As well as details of the Netgear router, the model number, how are you trying to connect these PCs? Wired to the Ethernet ports on the router?
What happens on the tower that won't connect? Any error messages?
The more detail you can provide, the quicker we can offer suggestions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The model is AX6600 and it is in the subject line. I want to connect 2 ethernet cables to 2 computers.
One connects but the other does not
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX70-100NAS
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW version is loaded?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure to check the PCs ethernet networking configuration. Should be configured for Auto-Obtain Networking. Contact the mfr of these PCs for additional help and information regarding there product. If one PC works and the other doesn't, the other PC needs to be reviewed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you - I will try it
- Mark as New
- Bookmark
- Subscribe
- Permalink
We still don't know what happens when you try to connect the second computer.
There are usually error messages or prompts of some sort when you try to plug it in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It does not have internet connection.
Again, that's a bit thin on useful details.
The PCs can see each other and it is just the Internet on one that doesn't work?
If this is a Windows PC, which version and what does it say in Settings > Network & Internet?
Have you tried the network troubleshooter in Windows?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
