sanketprajwal
Dec 07, 2022Initiate
Antenna Part Number: NETGEAR RAXE500
Hi ,
I am trying to get the Part Number for Antenna Pigtail - SMA Connector to Rewire the Antennas of RAXE500.
It would be helpful if I could get the part number. Please let me know.
Thanks,
Prajwal
You can try checking on the fcc site to see if they're stock units or not for the part you're looking for.
https://fcc.report/FCC-ID/PY320300508/5205951
- sanketprajwalInitiate
Thanks for the Info. However, I couldn't find the exact Part Number for the Antenna Pigtail from the Documents
I don't think you will. Netgear doesn't even sell replacement antenna's for the routers with detachable antenna's so I highly doubt you'll find them for the ones integrated into the wings on the raxe.
