Jipinp
Sep 01, 2023Aspirant
High latency
Hi am facing high latency in gaming . More than the original router. Is there anyway to reduce it please help ..
What model NG router do you have?
What gaming device are you using?
Wireless or wired for gaming?
- JipinpAspirantMine is rax80 ax6000
I live in uk my internet provider is virgin media
1 gbs download and 100 mbps upload I use iPad to play Pubg mobile I have a tp link ax1500 I get latency of 12ms but when I connect on nighthawk I have latency of 30 ms and experiencing high lag- FURRYe38Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Some Virgin Media have routers built in to there modems. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
