Aandrey
Jan 20, 2024Tutor
Re: Can't Reach This Page, then fixes itself after a second
Hi, sorry if this post is in the wrong place.
Got a Nighthawk X8 model R8500 and its firmware is outdated. It produces a network, but has no internet ("connected without internet"). All the documentation for updating firmware tells you to connect to the Router, then navigate to a webpage to login routerlogin.net. I can't navigate anywhere because there is no internet on that network.
On the Nighthawk phone app, same problem, you're supposed to connect to the Router and then get the firmware update. But the router can't reach the internet, so what am i supposed to do?
I have the latest firmware downloaded on my PC, i can put it on a USB drive, or I can connect to the router via ethernet. But how do i get it to take the file from my PC / the USB drive?
Thanks in advance.
- AandreyTutorSo RouterLogin.net did not work, it wouldn't display the webpage. But 192.168.1.1 worked If anyone was having my problem, once you log in to 192.168.1.1 (default creds are admin/password) you need to go to the advanced tab, then Administration, and then Router Upgrade. It will then give you an option to upload the firmware update file from your PC. However, this didn't do anything for my real problem, as the router is still "connected without Internet" even after successful upgrade to the latest firmware. - AandreyTutorFurther update: I checked the router status in the Advanced--> administration menu. The ip showed 0.0.0.0 which meant the router couldn't get an IP. so I hard rebooted the modem and router together, and after reboot an IP was assigned and everything works now!- michaelkenwardGuru - Experienced User
 Aandrey wrote:
 so I hard rebooted the modem and router together, and after reboot an IP was assigned and everything works now!When you do that, remember that the timing is important.
 Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
