oric307
Feb 19, 2023Aspirant
NIGHTHAWK AC1900 DUAL-BAND WI-FI ROUTER
Hi: I would like to upgrade my NIGHTHAWK AC1900 DUAL-BAND WI-FI ROUTER.
Can someone recommend a router.
It must be compatible with EXTENDER EX7300, I have 3 of them.
EXTENDER EX7300 must connect wirelessly.
I have about 60 connected devices.
Thank you.
oric307
What AC1900 do you have? (ac1900 is a speed not a model)
Are you planning on upgrading the extenders?
Reason I ask is I usually recommend moving from extenders to a mesh (like orbi or mk nighthawk) system when you're needing more than 1 extender. And if you're looking at upgrading router's it might be worth upgrading the whole system.
Plus you'll only really see a speed benefit to the upgrade for the devices connected to the router.
- oric307Aspirant
Hi: I have the NIGHTHAWK AC1900 DUAL-BAND WI-FI ROUTER
- microchip8MasterDude,
AC1900 is a speed, NOT a model number. Look at the label on the router for model number. Most likely, you have an R7000.
