May 11, 2022Guru - Experienced User
New - RAX42/43/45/50 Firmware Version 1.0.11.112 Released
Bug Fixes: 05/09/2022
- Fixes the issue where Advanced Tab cannot function when using Safari Browser
- Fixes the issue where QoS priority setting cannot be saved after enable QoS.
- Fixes the issue where DHCP reservation cannot support maximum 253 IP addresses.
- Fixes minor bugs
Download Links:
RAX42: https://www.netgear.com/support/product/rax42.aspx#download
RAX43: https://www.netgear.com/support/product/rax43.aspx#download
RAX45: https://www.netgear.com/support/product/rax45.aspx#download
RAX50: https://www.netgear.com/support/product/rax50.aspx#download
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit:
https://www.netgear.com/support/product/RAX42.aspx#docs
https://www.netgear.com/support/product/RAX43.aspx#docs
https://www.netgear.com/support/product/RAX45.aspx#docs
https://www.netgear.com/support/product/RAX50.aspx#docs
NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
To Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
This article applies to:
Wireless AX Router Nighthawk (WiFi 6) (4)
Let us know how it works for you...Please leave feedback.
- microchip8Master
Flashed my RAX43. No issues
Can confirm 100% that the Safari issue and viewing the advanced tab has now been resolved. Many thanks.
Enjoy. 📡
1.0.11.112 also fixes the Advanced Tab bug for RAX50. My router auto-updated a few days ago and all is well.
- PaulGoLuminary
I have the RAX45 but this seems to be a bug in many Netgear routers. Comcast in some ares has implemented vCMTS. After an hour or two IPv6 is lost. I have been working with Comcast and Netgear on this issue and after nine months of sending me test builds and finally Netgear tested their own setup with the help of Comcast. Then I was sent a test build and it resolved the problem. It should be released for my router and similar routers by September. Hopefully this fix will be released for all Netgear routers.
