×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Nighthawk RAX45 - Where is the Transmit Power Control after latest firmware update?
uwdj75
Follower
My Nighthawk RAX45 router is updated to firmware version V1.0.11.112_2.0.77.
I cannot find the Transmit Power Control anywhere. Did Netgear remove that option from the firmware? (It used to be on the Wireless Settings page.)
While watching TV I normally sit about 2 feet from the router, so I would set the Transmit Power to 25%.
Message 1 of 5
microchip8
Master
Re: Nighthawk RAX45 - Where is the Transmit Power Control after latest firmware update?
Transmit power is fixed as per FCC demands. I guess that's why NG removed it. To comply.
Routing: NETGEAR RAX43 - Firmware: v1.0.12.120 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2)
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 5
回复: Nighthawk RAX45 - Where is the Transmit Power Control after latest firmware update?
Transmit Power Control was removed from v1.0.11.112.
Message 3 of 5
tallpeak
Then the UI should show the current setting, 25% (where I left it) or 100% (if forced to that new value by the firmware update), grayed-out to indicate that I cannot change the transmit power anymore. Removing the functionality while hiding the fact that it was removed was confusing! (Is it at 25% now, where I left it? I'm only getting 2 out of 5 bars, 30 feet away...and it works okay I guess, but I lose packets sometimes; it might work better at 50%, or do I need to move the router closer?)
Message 4 of 5
Guru
More then likely the power is at 100% after you did the FW update. To ensure this, do a factory reset and setup from scratch. The UI should read 100% or grayed out or no longer appearing in the UI.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 984 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 6E
