- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
No 5ghz SSID when setting 160mhz channel - RAX50v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just opened the box and setup RAX50v2 with Firmware Version V1.1.3.18_2.1.14.
On setup no 5Ghz wifi was showing up. I changed the channel size down to 80mhz and it works like a charm. Back to 160mhz, no 5Ghz SSID.
Is this the expected behavior if I'm near radar (I live right near an airport in the USA), or is the router defective?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: No 5ghz SSID when setting 160mhz channel - RAX50v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try changing the channel to the lower 5ghz channels when you have it set to 160hz. See if that helps.
Are you using smart connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not using smart connect.
I moved it all the way down to channel 36, no change in behavior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you check if its set to the proper region?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, set to United States.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might have radar in the area thats causing it. Wouldn't be the first time that someone had unknown radar/weather radar in the area
- Mark as New
- Bookmark
- Subscribe
- Permalink
I checked out my RAX50v2 today with a RAXE500 in wireless bridge mode:
Set channel 64 DFS on the RAX50v2:
I'm impressed, 4300Mpbs connection rate seen on the RAXE500 at about 5 feet distance:
