× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX-120: android devices fail to obtain IP address
Retired_Member
Not applicable
Hello,
I Just purchased the RAX-120, set it up, all my home devices connected just fine. I went to device manager, renamed a few (including the device which now fails to connect ), a hour later the nighthawk app said there was a firmware update, I performed the update, and ever since my Lenovo Tab Plus with Android 11 fails to obtain an IP address.
Anyone have this issue? Or have non obvious pointers ? No, the device is not being blocked deliberately. I have the device access feature disabled.
Thanks in advance
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 6
Retired_Member
Not applicable
Re: RAX-120: android devices fail to obtain IP address
Some more information:
Router Firmware Version V1.2.3.28
The android device in question is using a randomized mac address by default. I've turned this off to use the actual device hardware mac address to rule this out as an issue.
All other devices, from iOS to macOS to nest thermostats to myq garage door openers work just fine with this router.
Also, if i plug in my Netgear R7400 then the android device is able to get to obtain an ip address just fine.
I wonder if the issue is related to bug fix #2 on this firmware release:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/New-RAXE500-Firmware-Version-1-0-8...
Message 2 of 6
Guru
Message 3 of 6
Retired_Member
Not applicable
Yes, since the last FW update a factory reset has been performed without any avail.
Message 4 of 6
Guru
What happens if you revert back to a working FW Version?
Message 5 of 6
Guru
I guess not.
Good Luck.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 960 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
