× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
RAX120 v RAXe500 performance
RAXuser
Guide
I have a RAX120 that is limiting my speed to about 940MB down.....   both my modem (arris s33) and my ISP support 1.2GB.      If I upgrade to a RAXe500 will I be able to utilize the full (or close to) 1.2GB?    Any other recommendations to increase my speed?     Thank you!
Message 1 of 12
Accepted Solutions
Guru
Re: RAX120 v RAXe500 performance
@RAXuser wrote:
1. To be connected to the S33's multigig port  - Completed
2. to be connected to the RAX120's multigig port from the S33 - Do I change the below setting to 5G Ethernet port or the Wan Aggregation?
Thank you again for your help!
If you've connected it to the 5g ethernet port, you'll change it to that port.
Then check the wan port statistics to ensure its connected at multigig speeds
Message 6 of 12
All Replies
Guru
so you're a little stuck. Both the the RAX120 and the RAXE have multigig input. But not a 2nd multigig port for output. So the router might be getting multigig but its challenging to get it out to devices.
Both have lan port aggregation that can get you multigig speeds but not many devices support it.
You're (more than likely) still getting multigig from the S33. An easy test would be to run a speedtest on the hardwired device and a wireless device at the same time. It should hit faster than the 1 gig speed. You can also use the built in speedtest in the nighthawk app to see the faster speeds.
Do you really need to make the large investment to hit multigig? Thats debatable as most sites won't saturate even gigabit. Because if they did for everyone, their server/ISP costs would be astronomical. Usually the only time you max out a gigabit line is during speedtests. Even streaming 4k only takes 25-40mbps.
So unless you're moving truly massive downloads, its not going to impact your usage much.
But it does feel better during testing.
Message 2 of 12
RAXuser
Guide
Thanks you for all the great info, very very helpful.
  One question related to your comment:  "You can also use the built in speedtest in the nighthawk app to see the faster speeds."
When I run the Nighthawk app speed test I am seeing the 940 speed consistently.   Are you saying the I should see closer to the 1.2GB?
Message 3 of 12
Guru
yes you should. 2 things you'll need.
You'll have to go into the RAX's settings to ensure the internet connection setup is set to get its connection from the multigig port.
Once you've done that, you can check that connection.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Message 4 of 12
RAXuser
Guide
Message 5 of 12
Guru
Message 6 of 12
RAXuser
Guide
@plemans You are amazing......   you literally saved me from doing something stupid (buying a RAXe500) today.    Thank you so much!     I went from 940MB to 1.4GB!!!!      IMG_3703.png
Message 7 of 12
Guru
Glad you got it fixed!
Before upgrading to a newer router, if you're on xfinity (which your speeds tend to indicate), you might be in an area with the mid split upgrade. meaning you can potentially get faster uploads. I noticed a difference for working from home going from the 40mpbs upload to the 240mbps upload. If you don't work from home, you might not notice the difference.
Message 8 of 12
RAXuser
Guide
I checked.... not available yet in my market.     I am however looking to dump Xfinity for Verizon 5G home.....    I need to install an antenna (check out natar tater on youtube) to get the best 5GUW signal...    Here is a the speed I get on my old iPhone 12 standing outside.    It is incredible.   IMG_3705.jpeg
Message 9 of 12
Guru
Seems like some solid speeds. I didn't really notice much difference going from a 300mbps download to a 1.2gig download. So you should be pretty set with those speeds unless someone in your home uses massive mounts of data.
Not sure if they cap it or restrict speeds at all through. My parents use a verizon home 5g but are limited to a 50mbps line (but they're on a cheaper plan)
Message 10 of 12
RAXuser
Guide
Still limited to 40MB up.....   I live a in a small market, they always get upgrades to us last!
Message 11 of 12
Kitsap
Master
I agree, @plemans does do good work!
Keep in mind, Xfinity has not released the updated firmware to allow the SB33 to connect to their Next Gen network.  Maybe by the time the physical upgrades are in place at your location, the firmware will be released.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 3662 views
  • 9 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
